Morning. I'm assisting a fellow tech with a strange issue on an iR5570. The problem he is having is a jam code of 0102, delay jam at pre registration(PS28). He has replaced the Duplex verticle feed assembly, pre registration motor, ps 24 & 28 and the DC Controller. We even added an extra wrap to the springs on the sensor flags. In service mode under parts check>motor he can watch the motor turn and in I/O mode you can see that the sensors are working. In copying mode it is a different story. The bypass tray is the only source of feeding paper at the moment. Any other drawer will jam even with using different sizes of paper. We thought that the side door was warped and tried applying pressure to the door as it copied-no change in the out come.
Any other suggestions that we may have missed?
angentx
angentx
