IRC-5185, heavy stock hitting fuser?
  • mutti8000
    • 6
    Hi folks
    I got a problem with one of our irc-5185.
    Please see the attached PDF file, I go a stange "smeared" line vertical nearest the trailing edge of the sheet, it is like the sheet hits somthing before geting fused, but i am not able to determine what? It does not happen on thinner stock, but with 160gms and above.
    And while you are looking at my PDF what is the faded horisontal line (cyan drum is brand new)
    best regards
    Morten
  • Fer
    • Nov 2009
    • 267
    Try adjusting fixing speed (FX-SPD2) u could also disable arching control (FX-LP-SW2)
    U can find those in Lvl2 copier > Option > Body >
    • Van Steal
      • 177
      Try the secondary transfer roller
      • Herrmann
        • Jan 2006
        • 792
        The thin white line could be something in the Laser Path, maybe Dust.
        I assume, that you are feeding SEF, if so, one can see, that the print is inclined. Looks for me, if the feed assy and the fusing assy are not parallel to each other.
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Originally posted by mutti8000
          Hi folks
          best regards
          Morten
          Hi Mutti
          Print a PG-10 test to check drums.Also you can open right cover and check
          the transfer belt when machine printing.Maybe you have an issue before fixing.
          The third option is laser issue.
          Try and report.
          good luck
          • charm5496
            • 2387
            are you just getting the line line one color or in all colors?
            On the line on the heavy stock it could drum drive, fuser drive, fuser assembly if adjusting the timing didnt help.
