Image runner error
+ More Options
Posts
  • BIG PAPA
    Da Boss
    • 234
    Image runner error
    Hey guys, got a call from a customer that has an image runner, not sure what model. I am a Konica Minolta tech not Cannon. Error E 0000-19-0000. Hoping to point them in the right direction. No Cannon dealers in my Area.
    sigpic
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5005
    This code is usually fuser error.For more info you need specified the model.
    • BIG PAPA
      Da Boss
      • 234
      Thank you, will probably just quote replacement, but that is up to my boss.
      sigpic
        • 22997
        I beg to differ, zoraldinho. E000019 is a waste toner full indication, regardless of what Canon model you have. Ordinarily I don't answer posts when the poster can't identify a model, but this is an easy one. =^..^=
          • 22997
          How will you quote a fuser if you don't know what model it is?
          • BIG PAPA
            Da Boss
            • 234
            Wont, as I said we are Konica Minolta. Not getting into Cannon. Using it as a lead.
            sigpic
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Just empty waste toner bottle, turn copier off, then on, problem resolved....
              • Canuck
                Tech Specialist
                • 1713
                Universal code for waste full on Canons. Depends what model. 3300 family,empty,clean spout. Larger products(600,5000,7105,etc),empty,then reset counter in service mode,....others,change bottle
                • kuby
                  • Oct 2007
                  • 1394
                  Waste toner bottle for sure....ir2200-3300 series
                  E019
                  0000 The waste toner case is full of waste toner.
                  Main cause The waste toner case is full. The waste toner case full detection mechanism
                  is soiled. The waste toner sensor is faulty. The DC controller PCB is faulty.
                  Caution To clear the error, dispose of the waste toner, and turn off and then on the
                  main power switch.
                  Action If the error is still indicated after disposing of the waste toner, perform the
                  following:
                  1. Waste toner case full detection mechanism
                  Remove the waste toner case, and turn off and then on the main power
                  switch. Is 'E019' absent?
                  YES: The waste toner case full detection assembly is soiled with toner.
                  Clean both inside and outside of area A of the waste toner case
                  with alcohol. Make sure that no dirt remains inside and outside the
                  area around the round recess.
                  • zoraldinho
                    • Mar 2008
                    • 5005
                    My mistake gays.I so all zeroes.Now im going to punish myself.
                    • pjdbm
                      • Sep 2007
                      • 360
                      [ATTACH=CONFIG]7667[/ATTACH]
                      Hey leave the gays out of it
                      • Eddias
                        I laughed too loud
                        • DAG COPIERS & COMPUTERS
                          • Oct 2010
                          • 860
                          HA HA HA HA.....HA! I laughed too loud too!!!. I suggest he should surrender that deal to a canon GUY if he cant handle, to save the customer unnecessary / unjustified expenditure.
