IR3235 half blank copy
  • bostjanma
    Hi all,
    I have specific problem on IR3235 with half paper blank copy?! See attachement!
    First I have to changed drum unit, developer unit and right hand door (complet ), RAM and ther is no result! If enybody have some other idea please write.
    THNX
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Originally posted by bostjanma
    Hi all,
    First I have to changed drum unit, developer unit and right hand door (complet ), RAM and ther is no result! If enybody have some other idea please write.THNX
    Do you have some errors.
    What about clear MCON or DCON.
    Is this copy or print?
    Try to stop the machine in the middle of job end check where you lousing second half.
    • THUK
      • Jul 2008
      • 195
      hi,is it the same when you print and get a report out or is it just copying from glass or feeder.
      • teckat
        • 16083
        Hi all,
        THNX
        Simple ??
        Is that page from when u use the Doc.Feeder ??
        If so your docs from tray are not being read correctly
        • rajmer
          • Dec 2008
          • 22
          Hi!
          It is the same problem vith print or copy.And yes I have one time code E315-0561
          THNX
          • teckat
            • 16083
            Originally posted by rajmer
            Hi!
            THNX
            what are u talking about ?? are u answering the posters issue- don't think so ???
            • rajmer
              • Dec 2008
              • 22
              We are together in the same company
              • teckat
                • 16083
                what does E315, have to do with half blank issue ??
                if that is a received FAX issue, it may
                • linuxxpwin
                  • May 2008
                  • 205
                  Good day, ticket ask if you are having the issue from the glass when u copy or from the doc feeder, if the problem occurs from doc feeder and not tray then u may have doc feed configurations issue.
                  Can you generate an internal print sample and see if the problem exist?
                  All i ask here is exactly what ticket is asking.
                  If u r unsure of what u r doing contactva field technician.
                  • rajmer
                    • Dec 2008
                    • 22
                    Hi!
                    I have the same problem if I copy from the doc feeder,glas or printing.
                    • zoraldinho
                      • Mar 2008
                      • 5015
                      Hi all,
                      THNX
                      Is it maybe staking receive fax?? I think this is:
                      • Fer
                        • Nov 2009
                        • 267
                        Maybe the transfer roller is bad, has flat spots or not seated properly. Causing the paper to slip/halt at the drum.
                        • teckat
                          • 16083
                          Check your all cassettes set up /paper sizes
                          if u notice image is exactly in half/ this is not a transfer issue
                          what size paper is your posted image issue on ???
                          what was that posted image - a scan/ a copy/ a print/ a fax ????
                          • rajmer
                            • Dec 2008
                            • 22
                            Hi!
                            The casettes is set properly,and I have replaced the tran.unit.
                            The posteed image is copy,but it's not the image always in the middle of copy.
                            • DAG COPIERS & COMPUTERS
                              • Oct 2010
                              • 860
                              Since the half print problem occurs on all the functionalities ( copy, print, fax?) , and your cassetes properly configured, and u say u have replaced dev unit, transfer etc, I would rule out the CIS or reader unit in the equation. I suggest however that you explore the possibility of replacing the Main controller pcb. It is possible it has a problem with the image processing function. Remember that from the main pcb the image is sent to DC controller to control the laser drive signals. Keep trying.
