Canon IR 3300 Remote UI
  • kishore
    • Aug 2025
    Iam having canon ir3300, iwould like to install and use remote UI feature.
    when iam trying to use this feature from my browser iam getting a message remote UI content is not found.RUI Module Version : 4201. i have cheked in my machine remote UI feature is on and checked the RUI Version also it is showing VER:40.01,can any body help me,how can i install the latest version of RUI in my machine.what are the requirements to do the same.
    Thank you
  • kuby
    • Oct 2007
    • 1409
    Upgrade to ver. 45.01
    • kishore
      where can i get the software and how do i install,please guide me,could you please explain the complete procedure....
      Thank you sir..
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Have you tried to PING the IP address of the copier? Were you successful?
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Thank you sir..
          Sorry but you can t do it yourself.You don t have experience and tools for upgrade.
          Better solution is calling Canon service.
          • teckat
            • 16083
            Thank you
            are you authorized to access RUI ???
            enable HTTP and RUI on the copier.
            enable "Dedicated Port" on the copier
            For MEAP Enabled Devices, please make sure that the proper MEAP version in Service Mode/Copier/Display/Version is also installed.
            If everything fails, perform a Clear MMI. Also note that on MEAP enabled devices, USE HTTP under TCP/IP Settings and USE HTTP under MEAP Settings must be ON.
            • kishore
              yes i sucessfully ping the copier and making prints also..
              • khoacoitnt
                • Dec 2010
                • 28
                Thank you sir..
                For upgrade, you need Service Support Tool and Firmware for Ir3300
                • kishore
                  i have tried all these things except MEAP,i have not find any feature called MEAP in my copier.could you please tell how to check whether my copier is MEAP enabled or not.
                  Thank You..
                  • kishore
                    where can i get it any links .
                    Thank You..
                    • teckat
                      • 16083
                      best bet >>>>>>>>>>place a service call for Canon tech.
                      • mrfixit51
                        • Oct 2008
                        • 1975
                        Thank You..
                        Your copier is not MEAP enabled, you would need to have a 3320 to have access to MEAP.
                        I had problems last week with my own laptop not getting into the RUI of a copier after I screwed up an import of the Additional Functions in RUI. All attempts to get back in would not allow me to bring up the screen I wanted. Reloaded RUI and still could not get in. I then had a calm moment and remembered reading somewhere about clearing the browser cache. So I flushed all the IE cookies, files, etc, and I could then communicate once again. Worth a try!
                        If that does not work, I suggest you load the latest system software in it's entirety, so that all versions are known to be compatible with each other... No ,, I do not provide software.
                        • teckat
                          • 16083
                          Thank you
                          Are u using Firefox or IE8 to access ?
                          Is your PC OP Vista or XP
                          You can try to swap RAM with another 3300 if possible
                          Try connecting your Laptop w/ a crossover cable to 3300 printer to access RUI- report back
                          CLEAR MMI in service mode, (Be sure to print out all user settings prior to performing MMI Clear,
                          They will be erased when MMI is cleared
