back ground on lead edge iR3300
  • imagewalker
    • Jun 2010
    • 94
    [Misc] back ground on lead edge iR3300
    Back ground on lead edge on a iR3300,has a new drum and charge roller.
    seems to only happen on the first page then it goes away,its about a 1/4 inch on the ledge edge of the copy in every tray. Its almost like it has residual charge or bias left over from the last copy cycle. Thinking on changing the developer unit next????
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Probably but one picture says a 1000 words.Put a sample.
    • Canuck
      Tech Specialist
      • 1713
      Does it do it on prints? If not, run 5 copies of 1 page from glass(will only scan once)1st bad,rest ok? If so, print engine issue. If all bad, poor scan lamp or inverter. Isolate whether it is reader or printer
