iR4570 - Finisher Jam...
  • y_us1982
    [Jamming] iR4570 - Finisher Jam...
    anyone had idea about finisher? my ir4570 get paper stuck at the finisher. i had check the finisher and it seems ok, but if i run a copy the paper will miss-feed at the end of the finisher. it happen after a year this machine running. is it the roller problem? i had try clean the roller but it still the same.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    [ATTACH=CONFIG]7957[/ATTACH]
    It's smell like moist paper.How many copies have copier?
    • y_us1982
      even 1 copies the paper will jam. i had try used a new paper but still the same, the finisher can't pullout the paper.
        • 16083
        what finisher is that ??
        something does not look right !!!
        u have a corner bend on paper, may be hitting guide to cause delay
        did u clean those rollers ??
        they become slick with paper dust-
        what is the jam code in service history -
        • charm5496
          • 2387
          That is an S1 finisher. We have had issues where the rollers were not going down far enough to grab the paper and causing a jam similar to yours. We either weighted down the arms or took flat lead wire and rolled it on the shaft under where the tire sits. This will force the tires down further.
            • 16083
            Good Point on MacGyver fix,
            without these discovery fixes from techs.,
            half of these imageRunner Finishers would never work.
            U also need to inspect those crappy offset rubber rollers
            • CanonSco
              Man About Town
              • Jul 2010
              • 368
              As said, replace those offset rollers, lose the white deflector plates ( showing at the very front of your picture, one also at rear ) and check the finisher input guides as I have had to replace a few for being warped.
              Yes, I am a nerd.
              Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
              • mrfixit51
                Lead Service Technician
                • 1975
                You should be getting a jam code with this problem,, off hand it could be the entry sensor not working correctly causing this issue.
                • Brian8506
                  • 1665
                  You know those little dampers on the guide on the right door? Well they have them in the finisher too. The rear side where the plastic arm lifts and lowers the tires hits a pad on the frame and also the white piece below it has one on top that can get mushy. Sorry if my description sucks but I had problems where the copies weren't stacking well, getting pushed out on the floor and end up all over the place. I took the top covers off the finisher to replace those parts and found the pads. Hope this helps because that one can drive you nuts.
                  • y_us1982
                    sounds like possible. charm, could u please give me a pict how you work on weighted down the arm?
                    • y_us1982
                      the rubber work fine, i think i need to try replace the rubber rollers also. what is the code no for the rubber roller since i dont have catalog for the finisher.
                      • y_us1982
                        sorry i cant remember the jam code because the machine at my custmr place. i had replace the entry sensor but still the same.
                        • Canuck
                          Tech Specialist
                          • 1713
                          Do the rolls drop into position and rotate? Does it do it from all trays,all paper sizes,bypass... If everything mechanically is working and nothing obstructing then possibly a lazy delivery sensor before finisher. Jam code is helpful. Image is registered properly on paper?
                          • y_us1982
                            i'm still work on the jam code. once i get the jam code i'll post it.
                            • y_us1982
                              i found the jam code is 0207
