error code 240
  • florintoni
    • Oct 2010
    • 38
    error code 240
    Hello
    Could anybody tell me how could i reset error code 240 at canon cp660. I don't have service manual for reader unit. Thank you!
    Flo
  • wil chow
    If im not wrong, Press the User Mode Key then 2 & 8 together then User Mode Key again.
    1) Select FUNCTION>CLEAR in service mode.
    2) Press 'ERR' to highlight.
    3) Press the OK key, and turn on and off the rear power switch manually; then, turn
    on the control panel soft switch to clear the E code.
    • teckat
      • 16083
      Originally posted by florintoni
      Hello
      Flo
      E240
      The communication between the DCcontroller PCB and the reader controller PCB is faulty.
      =The DPPRDY signal is not sent for0.25 sec or more from the reader controller to the DC
      controller PCB after the DC controller PCB is supplied with power
      • The communication between the DC controller PCB and the PS/PCL board or between the reader controller PCB and the PS/PCL board is faulty.
      =The signals between the PS/PCL board and the DC controller PCB or between the PS/PCL board and the reader controller PCB cannot be exchanged for a specific time after the PS/PCL board is supplied with power.
      • teckat
        • 16083
        You're wrong>
        CP660 SERVICE MODE
        To start service mode, turn on the printer unit while holding on the “Menu key,
        Enter/Online key, and Cancel key” on the control panel at the same time until “Start
        SELF-TEST” displays. The panel display will show “DISPLAY” to indicate that service
        mode has started after the printer unit checks itself.
        The modes discussed herein are effective when the printer board (PS/PCL) is installed, and may be started on the control panel of the printer unit.
        If the reader unit is installed, service mode must be started by operating on the control panel of the Reader Unit.
        See the Reader Unit Service Manual.
        • florintoni
          • Oct 2010
          • 38
          Thanks a lot Wil. It has worked.
          All the best
          Flo
          • teckat
            • 16083
            All the best
            Flo
            you should never clear an ERROR unless you investigate the cause ,
            it will eventually return !!!!!!!!!!!!!!!!!!!!!!!!!!
            u must be an End User/ a tech would never Clear Error without a Search first.
            • florintoni
              • Oct 2010
              • 38
              clear error
              hello Teckat
              You are wrong. Ive been reseting hundreds of error code during the time at any tipe of copier and i think you have made the same. At least one fuser error code must be.
              I think i am very lucky for most of them never return.
              all the best,
              Flo
              • teckat
                • 16083
                hello Teckat
                all the best,
                Flo
                sorry to say this but, you are a foolish person.
                do you even know how to describe the reason why an ERROR CODE appears on a printer,
                or the Function of having an ERROR.
                Companies don't have to have Errors programed in to their products, there is no written Law.
                They do so to protect Consumers like you from causing damage.
                You are like the customer who, on a NP400 was pissed off about the power switch tripping off, he went and tapped down the switch- plugged in machine to force it on, left the office & returned to see the Power switch Melted to the Frame
                • zoraldinho
                  teacher-guide-expert-guru
                  • Mar 2008
                  • 5015
                  Amen.
                  Always investigate error codes!!
                  • florintoni
                    • Oct 2010
                    • 38
                    "clever answer"
                    I'm sorry, but you didn't understand a thing. maybe you are to smart. I don't want to argue with you on this forum. It's not the place. So ,i would appreciate if you never reply to my questions.
                    Tip- try to be a normal person. you are speaking from high level and i don't know if it's the case, after the answers you gave me.
                    Good day
                    • teckat
                      • 16083
                      Good day
                      It was not an argument, I was stating a FACT, If you understood the Copy Process,
                      u would not have made that statement.
                      You are lucky that ERROR code was only for a miss-communication signal !!!!
                      • zoraldinho
                        • Mar 2008
                        • 5015
                        This is the strong one!!
                        • florintoni
                          • Oct 2010
                          • 38
                          let's clear it up ! I've asked a simple question, i've received a simple answer from Wil, and the problem was solved. Guess why? Because i knew exactly why the code appear. Could you imagine that ? I think it's time to complete this stupid discussion.
                          • zoraldinho
                            • Mar 2008
                            • 5015
                            i agree
                            • teckat
                              • 16083
