Canon IR2270 Jamming for no reason
  • nmfaxman
    • 1702
    [Jamming] Canon IR2270 Jamming for no reason
    I replaced the feed rollers and transfer roller. Everything ran fine.
    This morning customer called saying it was jamming again.
    Now it is jamming just past the fuser. 3 to 4 inches are past the fuser exit rollers and the rest is an accordian. Swapped the exit sensor and cleaned all the transport rollers.
    After 2 hours of cleaning and testing it started working all on it's own.
    Cust told me it tends to do that in the morning and stops later in the day.
    Any ideas???
    This is the only 2270 I work on and it is a billable account, but I have to get them running ASAP.
    Thanks for any input.
  • CanonSco
    Man About Town
    • Jul 2010
    • 368
    What jam code you getting?
    What mileage has it done?
    Could be a few things.
    Single or double sided? Does it on all sizes?
    Does the paper fully exit the fuser? Or is the trail edge still in the fuser?
    Thing to check / replace that are easy -If it still has the old black style vertical path rollers, change these with the new grey type. Check the internal 3-way lower vertical path roller ( on the green part that swings out the machine ) front bushing has not popped out / is lose. Is the lower RHS door foam strip in good condition> , if not replace it or even better replace the door and internal black guide with the IR32XX type.
    Hows the humidity? , fresh paper works a charm in the 2270.,
    good luck
    Yes, I am a nerd.
    Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
    • teckat
      • 16083
      Please supply Jam Codes /
      Paper select location/ prints or copies/ or both ??
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5005
        Any ideas???
        Hi dude
        This is standard issue for this models.Read this thread link.
        http://www.copytechnet.com/forums/ca...-paperjam.html
        • nmfaxman
          • 1702
          Code 108. Simplex.
          All sizes including bypass.
          As it warmed up jammed less.
          Zoraldinho pointed me in the right direction.
          Thanks for all the replies.
          I didn't know the 2230 had the same problem.
          Zoraldinho's reply pointed me in the right direction.
          • wil chow
            hope this can help you. Go to service mode *28*
            1. COPIER> ADJUST> HV-TR>TR-TP-TM & TR-TP-LV change to 50
            2. OPTION>FIX-TEMP change to 1
            3. TEMP-CON change to 7
            4. COMBO>MOD-SLCT change to 2
            5. TR-SW1 change to 1
            6. again MOD-SLCT change to 3
            7. TR-SW2 change to 1
            8. OFF & ON machine
            • nmfaxman
              • 1702
              The rubber noise suppression pads were the problem. The rear one was worn to the point that only glue was left.
              Thanks guys.
              • MrB
                • Nov 2009
                • 147
                If the jam code is 0108 try this..
                On the R/H door, you will find a flapper that sits on 2 pads
                Them pads over time get very worn, and the flapper sticks to them
                And it's normally the 1st pge ofthe day will jam
                When the jam is removed, this unsticks the flapper, and the machine works okay for the rest of the day
                and over night the flapper sticks again to the pads
                FIX...Change the pads
                Figure 354 in the parts man, and flapper is Item 13 (and pads are either side)
                Good Luck IF This is the case of your jam
                • zoraldinho
                  • Mar 2008
                  • 5005
                  Code 108. Simplex.
                  Any time.
                  • Brian8506
                    • 1664
                    Just finished one of these. The guy before me diagnosed it as fuser parts without removing fuser. Keep it simple!
