Ir3570 clearing logs
  • apollo
    • Mar 2008
    • 191
    Hi,
    I need to clear logs off system monitor for Print, Fax & copy jobs on Canon ir3570 & ir3300
    looked in service mode and additional function, but no joy.
    there no option when you press system monitor & select print & log on display, no option to delete.
    any input would be appreciated.
    Thanks in advance
  • roho
    • Mar 2009
    • 844
    service mode-function-system-check type 2-hd clear
    reboot and the system monitor should be clear
    • apollo
      • Mar 2008
      • 191
      Thank you roho for info cleared logs with above instruction.
      • tammywoolls
        Re: Ir3570 clearing logs
        I was able to get into service mode-function-system....from this point could not get to check type 2. Monitor says level 1. I proceeded from here and did hd clear, however the print log is still on screen, nothing cleared. Can you please advise?
        • roho
          • Mar 2009
          • 844
          Once you are in level one simply press the additional function key and then 2. That will put you in service mode level 2.
