need help with ir-6000i touch screen not working
  • yazan
    • Feb 2011
    • 15
    hi , thanks allot for all admins and members here for this helpful site, thanks for sharing the info and experience
    i have problem with my canon ir6000i , the touch is not working but lcd is good and displaying .
    i remove the panel assy and i found there is a light glass with some electronic lines inside it and a transparent sheet - damage
    does this have part number or i should by all the lcd assy ?
    thanks allot for any help .
  • charm5496
    • 2387
    FB5-6846-000 is the sheet you are talking about
    FG6-9149-000 is the LCD
    FG6-5173-000 is the entire assembly
    • yazan
      • Feb 2011
      • 15
      thank you sir , thank you very much
      that what I am looking for , and am very sorry , my English is bad
      thanks again .
      • charm5496
        • 2387
        not a problem yazan. good luck on getting this unit repaired and working
        • yazan
          • Feb 2011
          • 15
          sir .. sorry for disturb. the glass ( that upon the LCD touch screen ) is broken in the corner ..
          can we buy this part alone ? or its included in the set ?
          and you mean the sheet ? that aluminum border with grounding to the back of the panel ?
          • teckat
            • 16083
            #1= is the static sheet=SHEET, LCD ELECTROSTATIC /FB4-6704-000
            # 20 is the LCD UNIT=LCD CONTROL PANEL UNIT / FM1-0186-000
            u probably need the LCD UNIT
            is the static sheet cracked or the LCD Screen ??
            need to remove to inspect
