Canon IR 1670F Drum reset
  • century
    • 95
    I have a Canon IR 1670F. recently, it pop up a message said "prepare to replace new drum". I check the drum and it still look good. How can I reset or clear that message. Thanks
  • Gleq
    • Feb 2007
    • 72
    hi
    Have u check the waste toner ? if no check and empty it
    goodluck
    • CanonHPTech
      • Apr 2007
      • 235
      I do not believe this model monitors drum life or page count, it only goes on how much the waste toner sensor is moving. If you hear a pretty consistant clicking as the machine is printing, that is your waste toner sensor. I have had no luck dumping the drums waste toner, but if you are in a bind (at least temporailry until you get a new drum), I have had luck removing the waste toner sensor flag that is on the rear of the front of the drum. I believe it is only a couple of screws and the little assembly comes off and your clicking and message goes away. Be warned I have never made this a permanent fix, so I do not know what happens if the drum becomes full of waste toner. Good luck sir.
      The glass maybe half full, but less is more...
      Printer + Fax + Copier = Jack Of Many Trades,
      but Master Of None
      Color Copier = Not A Color Printer
      InkJet MFP = Not A Fax Machine
      B/W Copier = Not A Press
      Finisher = Deal Closer (salesman, not accessory)
      Copier Tech = Admin's Stress Ball (Scapegoat)
      • century
        • 95
        Hi Gleg & Canon HPtech,
        Thanks for quick responsed. You all right, I have both message, waste toner full and need new drum. But I thought it is 2 separate problem. So, I'll try to remove waste toner and see what happen. Thanks again.
        • whileyourhere
          Service Mode-------Counters---------Use Up/Down Key to find Waste Toner-------Use the Clear Key to reset
          • century
            • 95
            Can you show me how to get in Service Mode on this copier. Thanks
            • whileyourhere
              To Enter Service Mode------- Press Additional Function Key and then the # key.....
              • century
                • 95
                Finally I clear the message. Thanks to everyone and Whileyouhere. You all have a nice weekend.
                • CanonHPTech
                  • Apr 2007
                  • 235
                  HOw did you accomplish this sir? Is there really a counter under service mode? I wasn't aware of one. Please let us know how you cleared the message. Thanks.
                  but Master Of None
                  • century
                    • 95
                    Hi Canon HPTech, I just did as "Whileyouhere" posted, and the message is gone. But it took me a while to figure out because he left out some small details.
                    Service Mode----Counters----Misc------Wst-TNR----Use the Clear Key to reset.
                    Clear key is on the left side (#12), you have to hit the FUNCTION key first then #12.
                    Also, I noted after I did this the clicking sound that you mention is gone too.
                    Thanks to Whileyouhere.
                    • copyman111
                      Reset
                      Will this procedure work as well on
                      Canon NP 1500 to reset "replace the
                      drum" message?
                      Thank you.
                        • 23009
                        I've had particularly bad luck with emptying waste toner on the small Canons. They collect quite a bit of paper dust, lint, and what-have-you. A lot of that what-have-you is quite abrasive, and if it's caught under the cleaning blade it will take out the drum in (2) t-w-o copies. I guess you've got nothing to lose if the waste toner light is on. Just don't be altogether surprised........
                        • lkrsardis
                          • Dec 2007
                          • 316
                          drum
                          hey guy
                          if you dont replace the drum it WILL come back.
                          WE rebuild a lot of those drums and you will need to remove and clean the waste toner actuator shaft bushing area, even if you just empty the drum unit,been there done that.
                          Like the United States Postal Service It's a miracle it works!
                          • Canuck
                            Tech Specialist
                            • 1713
                            Its an np1500...don't waste the money on the drum...use it as a boat anchor
