Canon NP3050 how to replace drum?
  • robocat
    Hi, I am working with an old (-92) NP 3050 and all documents are missing. I need to do some adjustments and replace drumblade and clean everything.
    The problem is that I cant get the drum out! Obviously I need some sort of command/funktion key or whatever to retract the tonerscrew (or what it's called...). I would really appreciate if someone could help me.
    Thanx.
    Robert
    Sweden
  • rambo40
    • Oct 2007
    • 21
    Np 3050 drum removal
    Hi Mate,
    You have to release the developer assembly in service mode.To get into service mode open the front door and insert a straightened paper clip in the small hole just on the right side near the door strap (if I remember clearly,it has been a while),oh also leave the power on when you do this and if you get it right a small $ sign will appear on the display .Once the dollar sign appears ok,shut the front door and type *4*(if you can cheat the door switch by inserting a key or similar item then it will be better because you can see if the developer moves away).Select the F006 DEV-REL screen by using the copy density key then press * to execute.The dev release solenoid operates and the dev moves to the right and stops.
    Now the drum can be pulled out.Press reset button to get out of service mode.
      • 23010
      These drums are only good for 200k. If your not cleaning, and close to that 200k just replace it. These drum units come as an assembly so they're quick & easy to change, assuming you can get one.
      • robocat
        Finally got it out!
        Thank you for your help!
        // Robert
