CANON IR3030
  • gitana1983
    • Mar 2009
    • 141
    CANON IR3030
    Hello everybody,
    i have been looking for the parts manual for this model but i don't find it, also i need to make sure that it includes the document feeder on it, therefore i am wondering if anybody know the part numbers for the adf pick up rollers, i need the pick up roller, the reverse roller and the belt part numbers, if anybody has them i will appreciate it.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5012
    If you have DADF N1 use this parts list.Enjoy.
    1 FB5-9434-000 2 SPRING, LEAF
    2 FC5-4323-000 2 ROLLER, REGISTRATION, 1
    3 FC5-4324-000 1 ROLLER, REGISTRATION, 2
    4 FB5-9438-000 2 SPRING, LEAF
    5 FC5-4326-000 1 LEVER, OPEN/CLOSE
    6 FB5-9440-000 1 SHAFT, LATCH
    7 FC5-4327-000 1 LEVER, LATCH
    8 FC5-4329-000 1 FLAG, DOCUMENT SENSOR
    9 FC5-4336-000 2 LEVER, STOP
    10 FC5-4424-000 1 CLIP
    11 FC5-4425-000 3 CLIP
    12 FL2-0948-000 2 SHUTTER
    13 FL2-0953-000 1 PANEL, OPEN/CLOSE
    14 FL2-0955-000 1 GUIDE, OPEN/CLOSE
    15 FM2-2955-000 1 SEPARATION ROLLER ASSEMBLY
    16 FS7-2663-000 1 SPRING, TENSION
    17 FU5-3333-000 1 PULLEY
    18 FM2-2958-000 1 PICK-UP ARM UNIT,REAR
    19 FU5-1168-000 1 BUSHING
    20 FU5-0628-000 1 GEAR, 18T
    21 FU5-1172-000 1 BUSHING
    22 XF2-1606-135 1 BELT, TIMING
    23 FM2-2957-000 1 PICK-UP ARM UNIT,FRONT
    24 FC5-4341-000 1 GUIDE, SEPARATION ROLLER
    25 FC6-2784-000 1 ROLLER, PAPER SEPARATION
    26 FC5-4338-000 1 COVER, REGISTRATION ADJUSTMENT
    27 FM2-2956-000 1 PICK-UP ROLLER ASSEMBLY
    28 FL3-1987-000 1 SIDE PLATE
    501 XD3-2200-102 2 PIN, PARALLEL
    502 XB4-5300-806 9 SCREW,TAPPING, TRUSS HEAD M3X8
    503 XD2-1100-502 1 RETAINING RING (E-TYPE
    Fig.P11 NPN RF DADF ASSEMBLY
    1 FC5-4396-000 1 LABEL, HINGE CAUTION AB SIZE
    2 FF3-4608-000 1 CABLE, JOINT PI2,3,4 J3,13,302,303,304
    3 FC5-4400-000 1 LABEL, HINGE CAUTION
    4 FC5-4279-000 1 LEVER, SOLENOID
    5 FS7-2662-000 1 SPRING, TENSION
    6 FL2-2954-000 1 SOLENOID SL2 J10
    7 FL2-0961-000 1 PANEL, FRONT
    8 FC5-4264-000 1 SHAFT, OPEN/CLOSE
    9 XH9-0126-000 1 SHEET, CLEAR DAMPER
    10 FC6-2778-000 2 ROLLER, DELIVERY REVERSE
    11 FF3-4306-000 1 CABLE, COVER/CLOSE SENSOR PI9,10 J14,309,310
    12 FL2-0941-000 1 PANEL, REAR
    13 FL2-0947-020 1 PANEL, COPYBOARD
    14 FF3-4607-000 1 CABLE, SOLENOID LED J11,14,201
    15 XA9-0894-010 1 SCREW,M3X6
    16 FG3-3800-000 1 CABLE, INTERFACE J1,2,12,401,402,403
    17 FC5-4428-000 1 SHEET, BLANKING
    18 FC5-4280-000 1 BUSHING
    19 FC5-4281-000 1 BUSHING
    20 FC5-4295-010 5 SHEET, COPYBOARD COVER, LARGE
    21 FC5-4286-000 2 ROLLER, PAPER FEED, 1
    22 FC5-4287-000 4 ROLLER, PAPER FEED, 2
    23 FB5-9401-000 2 SPRING, LEAF
    24 FC5-4285-030 2 SHAFT, PAPER FEED ROLLER
    25 FC5-4291-000 1 GUIDE, STAMP
    26 FC5-4293-010 2 SPONGE, COPYBOARD PANEL
    27 FC5-4399-000 1 LABEL, HINGE CAUTION
    28 FC5-4292-000 1 GUIDE, PAPER FEED ROLLER, 2
    29 FC5-4274-000 1 SCREW, ADJUSTMENT, M4
    30 FL2-0945-010 1 SHAFT, DELIVERY REVERSE ROLLER
    31 FL2-0946-000 1 GUIDE, PAPER FEED ROLLER, 1
    Fig.P33 FM2-2959-000 1 PAPER FEEDER ASSEBLY
    1 FC6-2785-000 1 GEAR, 17T
    2 XF2-1605-940 1 BELT, TIMING
    3 XF2-1607-440 1 BELT, TIMING
    4 XF9-0727-000 1 BELT, TIMING
    5 FC6-2781-000 1 PULLEY, 28T
    6 FC6-2791-000 2 TENSIONER
    7 FH6-5128-000 1 CLUTCH
    8 FC5-4354-000 1 ROLLER, REGISTRATION
    9 FL2-2952-000 1 MOUNT, CLUTCH
    10 FB5-9466-000 1 PULLEY, ONE-WAY
    11 FC6-2805-000 1 ROLLER, PAPER FEEDER, 1
    12 FC6-2806-000 1 ROLLER, PAPER FEEDER, 2
    13 FC6-2807-000 1 ROLLER, PAPER DELIVERY
    14 FM2-2961-000 1 ESTRANGEMENT CLT ASSEMBLY
    15 FB5-9471-000 1 DEFLECTOR, PAPER
    16 FL2-0965-000 1 FLAG, REGISTRATION SENSOR
    17 FC5-4358-000 1 FLAG, READ SENSOR
    18 FC5-4359-000 1 FLAG, PAPER DELIVERY SENSOR
    19 XF2-3616-660 1 BELT
    20 FB5-9477-000 3 SPRING, TORSION
    21 FC6-2804-000 1 ROLLER, PLATEN
    22 FB6-2705-000 1 RING,E,FRANGE
    23 FC5-4353-000 1 FLANGE, BELT
    24 FC5-4356-000 1 PULLEY, TENSIONER
    25 FC5-4363-000 1 GUIDE, PLATEN ROLLER, RIGHT
    26 FC5-4376-000 1 GUIDE, PLATEN
    27 FC5-4381-000 1 SPRING, TORSION
    28 FB5-9460-000 1 WINDOW, LED
    29 FL2-0958-030 1 PLATE, TENSIONER
    30 FL2-0959-000 1 ARM, SWING BUSHING, FRONT
    31 FL2-0960-000 1 ARM, SWING BUSHING, REAR
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Just use your iR2270 manuals, most everything is the same on the 2 series of copiers(4570-3045), except probably the main controllers...
