Hi There,
Has anyone come across this situation before, guess i have run out of options. Got this problem on one of my other client machine ir3300 on monday and everytime i copied a document the end result will have the writings layout different from the paper vertically upwards, the writings go bend not align with the paper vertical output, it is as if the paper is not inserted and properly lay on the tray.
Have already checked the paper tray, pick up rollers, separation rollers, paper pathway right into the developer and drum unit and through to the fuser unit, even tried adjustment settings and changed the whole pick-up unit but still can't solve the problem. Got to the last option of changing the board but i'm still having the fault happening, Is there something else that i haven't tried or is the cause for this?
Really appreciate your help.
