Ok firstly on the operation panel when I go into printer, settings- I have all the options avaialble except calibrate. Nothing has been done to this new machine except previous calibrations of both the machine and the fiery. Secondly on the othe machine, following re-installation of the firey software I now get a jam registered in the ADF every time go to scan a page during fiery calibration. Any help would be really appreciated as we are ricoh and utax dealers but one of our customers demanded these canons,5 in total- so we have litle experience of them. Cheers.
IR ADV 5045 B1 Fiery issues.
You can find calibration in:
Additional settings>adjustment/maintenance>adjustment image Quality
For your ADF issue you have probably 55.xx system version installed.
Use 45.xx or latest 56.xx.Last edited by zoraldinho; 03-14-2011, 08:27 PM.Practice makes perfect
If you want something done right, you have to do it yourself
There is a known issue that claims a jam in the DADF when trying to run the calibration of the B1. If the copier is at version 55 or higher, there is a patch for the B1 that needs to be installed...
I ran into this 2 weeks ago...
Article#77125
This Technical Publication is to announce the release of Fiery Patch 1-19Q9Q0 for the imagePASS-B1 v1.01. This patch resolves an issue where a jam is reported at the Automatic Document Feeder when a ColorCal calibration is performed on an imageRUNNER ADVANCE device with v55.xx (v2) firmware or above."Once a King, always a King, but once a Knight is enough!"
Article#77125
v55.12 with the ColorPASS-GX300, when attempting to perform a ColorCal calibration from the Fiery controller, a
0095JAM error occurs at scan operation. This issue also occurs when attempting to perform Fiery Remote Scan
without documents in the ADF.Practice makes perfect
acc-1052.pdfPractice makes perfect
