IR ADV 5045 B1 Fiery issues.
  • aabarnes1
    • Mar 2009
    • 620
    Ok firstly on the operation panel when I go into printer, settings- I have all the options avaialble except calibrate. Nothing has been done to this new machine except previous calibrations of both the machine and the fiery. Secondly on the othe machine, following re-installation of the firey software I now get a jam registered in the ADF every time go to scan a page during fiery calibration. Any help would be really appreciated as we are ricoh and utax dealers but one of our customers demanded these canons,5 in total- so we have litle experience of them. Cheers.
    Grant me the serenity to accept the things I cannot change.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5001
    You can find calibration in:
    Additional settings>adjustment/maintenance>adjustment image Quality
    For your ADF issue you have probably 55.xx system version installed.
    Use 45.xx or latest 56.xx.
    • Djzolla1
      • Feb 2011
      • 14
      I agree with the last reply to this thread, just upgrade the firmware.
      • mrfixit51
        Lead Service Technician
        • 1975
        There is a known issue that claims a jam in the DADF when trying to run the calibration of the B1. If the copier is at version 55 or higher, there is a patch for the B1 that needs to be installed...
        I ran into this 2 weeks ago...
        Article#77125
        This Technical Publication is to announce the release of Fiery Patch 1-19Q9Q0 for the imagePASS-B1 v1.01. This patch resolves an issue where a jam is reported at the Automatic Document Feeder when a ColorCal calibration is performed on an imageRUNNER ADVANCE device with v55.xx (v2) firmware or above.
        • charm5496
          • 2387
          reloading the firmware on the B1 and then installing the patch will solve your issues
          • zoraldinho
            • Mar 2008
            • 5001
            With 56.xx version firmware patch is included.
            • charm5496
              • 2387
              version 56 is for the copier. The patch goes on the B1???
              If he doesn't have access to the firmware then he will need the patch.
              • zoraldinho
                • Mar 2008
                • 5001
                Article#77125
                Under the environment of iR ADV C5000s using v2 firmware v55.10 or iR ADV C7000/9000s using v2 firmware
                v55.12 with the ColorPASS-GX300, when attempting to perform a ColorCal calibration from the Fiery controller, a
                0095JAM error occurs at scan operation. This issue also occurs when attempting to perform Fiery Remote Scan
                without documents in the ADF.
                • mrfixit51
                  • 1975
                  Not in my world,,, the patch must be downloaded from the Canon Support website. Bring up article #77125 in the Download area, and you get the link to the file, and the tech pub.
                  • zoraldinho
                    • Mar 2008
                    • 5001
                    Probably only in Disney world.I can't remember ho told me that but now I found the true.
                    acc-1052.pdf
