Image Combination Doubt...
  • rajan_rsx
    • Jun 2010
    • 17
    On the Display itself on selecting the option which says "SPECIAL FEATURES" we get another option named "IMAGE COMBINATION"... it gives ability to print 2 or 4 or 8 Images on one single side of a printer, (This is helpful in case u need to print certain pages of a small book into a single page to avoid flipping the pages again & again)...
    I would like to ask... in that... we have the following Options...
    2 on 1
    4 on 1
    8 on 1
    Is there any possibility... or any setting in Service Mode or anywhere... through which we can even add more number of pages in this particular Module..
    For Eg:
    12 on 1
    16 on 1
    ............... etc...
    SPECIAL FEATURES---> IMAGE COMBINATION--->SELECT ORIGINAL SIZE (A6)----> 2 on 1 / 4 on 1 / 8 on 1......
    Please check this out if possible guys... it would be really helpful...
    • 16083
    This is it / nothing more
    2 On 1
    This setting reduces two 1-sided originals or one 2-sided original to fit onto one side or both sides of one sheet of paper.
    4 On 1
    This setting reduces four 1-sided or two 2-sided originals to fit onto one side or both sides of one sheet of paper.
    ■ 8 On 1
    This setting reduces eight 1-sided or four 2-sided originals to fit onto one side or both sides of one sheet of paper.
      • 23008
      Come on, teckat. Why can't you write some new system software, and create some new keyboard functions?
      *snicker*
        • 16083
        Ready to Hack at your Request
        • bipc
          • Sep 2009
          • 194
          i imagine that canon's firmware isn't easy to hack into and change, it must be very time consuming
          Life is a learning continuum...
          • rajan_rsx
            • Jun 2010
            • 17
            ok it means it can't get above 8 on 1.
            But 2 more questions.
            1) Does it give Back to Back Output in Image Combinations?... does the Back to Back Print come alligned to the one in front.???
            2) Can it take copies from ADF & reduce it for Image Combination?
              • 16083
              NO/ next time post the machine you are working on/
              also u need to get a copy of your machines Copy/Mail Box Manual
              Image Combination mode enables you to automatically reduce two, four, or eight originals, as well as two-sided originals or the facing pages of a book, to fit onto one side or both
              sides of a selected paper (record) size.
              • Originals copied/scanned in the Image Combination mode must all be the same size. You
              cannot use the Image Combination mode with the Different Size Originals mode.
              • For the Copy function, you can change or specify the number of copies or 2-Sided
              Original mode before scanning the next batch of originals (i.e., between batches).
              • For the Mail Box function, you can change or specify the 2-Sided Original mode before
              The reduction ratio is automatically set so that the originals fit onto the selected paper (record) size.
              Combination's Unavailable
              Entire Image
              Poster
              Automatic Paper Selection
              Automatic Paper Selection, Auto Orientation
              Saddle Stitch
              Add Cover (Print/Leave Blank)
              1 2-Sided
              2 2-Sided
              2 1-Sided
              Book 2-Sided
              2-Page Separation
              Original Frame Erase
              Book Frame Erase
              Shift (Using the Numeric Keys)
              Front Cover
              Back Cover
              Sheet Insertion (Printed/Leave Blank)
              Chapter Page
              Tab Paper
              Transparency Interleaving
              Image Repeat
              Mirror Image
              Blanking
              Framing
              Form Composition
              Scan Image Check
              Tab Paper Creation
              Document Size Auto Select
              Record Size Auto Select
