canon imagerunner 5000 finisher problem trays lower, don't go up
  • mrfuser
    • 1617
    Client has an iR5000 with standard staple/hole punch finisher, 2 tray. Trays lower down and click and won't come back up. Is there a lower sensor that goes bad on these?
    Kelly
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5014
    Do you have error?
    • vigour
      • Aug 2010
      • 1038
      the sensor does not normally go bad, but the actuator might not be sitting correctly to block the sensor.
      Take the caps off and look down with a flashlight to check.
      A foolproof adjustment , is to take the tray assembly out completely, re-insert it slightly angled to the rear.
