DR 2020 U Scan lock error
  • Gerhard
    • Oct 2009
    • 99
    Hi Guys
    Ive got three of these buggers giving me this error when scanning. The scanner lock mechanism is mechanical and is set to the off position. Ive checked all mechanical operations and found no problem. Please shout if anybody has had this problem.
    Regards
    sigpic
    Life is a Journey enjoy the ride !!!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Do you have error when scanning or you can't scan at all?
    • Gerhard
      • Oct 2009
      • 99
      The scanner powers up fine. As soon as you instruct the machine to scan. The scanner moves 20 cm and the error appears on pc screan and display on scanner. The scanner does find home position at power on,but I cannot see any other sensing mechanism that checks the scanner unit.
      Thanx
      sigpic
      • teckat
        • 16083
        Thanx
        test to a service laptop to eliminate the scanner as a cause.
        There have been reports of this error occurring on workstations running certain antivirus software.
        • Gerhard
          • Oct 2009
          • 99
          Hi Teckat
          Tried with my work labtop and workshop PC . Same problem. The problem is scanner related. Ive checked extranet and their is no bulletins. By the way i have 5 of these buggers doing the same thing. What I have found from field technicians is that swiching of and on sometimes sorts out the problem. My thinking is firmware. The problem with these machines is that the replacing boards will render the machine uneconomical to repair.
          Regards
          sigpic
          • teckat
            • 16083
            Hi Teckat
            Regards
            My friend said to reload the driver ver. below/ see Canon Link
            DR-2020U ISIS/TWAIN Driver version 1.1 for Windows 2000 SP4, XP 32bit SP3, XP 64bit SP2 (Emulation Mode), Vista 32bit SP2, Vista 64bit SP2 (Emulation Mode), Windows 7 32bit and Windows 7 64bit (Emulation Mode).
            Canon U.S.A. : Support & Drivers : imageFORMULA DR-2020U Universal Workgroup Scanner
            • Gerhard
              • Oct 2009
              • 99
              Thanx for info I will do so will let you know.
              Regards
              sigpic
