iR 6570 ADF problem
  • nizam
    • Mar 2011
    • 40
    [Misc] iR 6570 ADF problem
    Correct size not recognized when copy original in ADF A4R & LGL . they A4 & A3 is correct sizes to copy, i put into A4R in ADF the copy became STMTR sizes tray 3&4 ,bypass. i put A4 paper in ADF the Feeder sens A4 ,A3 is A3 & A4R & LGL the feeder sens A3 ONLY THIS PROBLEM IN ADF Pls....... Any suggestions? Thank You.....
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Do you try to install Tray width?
    • charm5496
      • 2387
      Is the machine reading correctly off of the glass?
      Also make sure that COPIER>OPTION>BODY>MODEL-SZ is set to a '1' if you are only running european size papers. cycle power if you change this setting.
      • nizam
        • Mar 2011
        • 40
        Yes, Install Tray Width But No Change
        • nizam
          • Mar 2011
          • 40
          i set the value but the same problem
          • charm5496
            • 2387
            clean your sensors and do sensor adjust on the DADF something is causing the machine to read incorrectly.
            Are you having the same issues on the glass???? If you are then you need to check your scanner.
            • teckat
              • 16083
              replace the tray width sensor
              Detecting the Size of the Original in Width Direction.
              The width of an original is detected using the original width detecting volume (VR1) found inside the original tray.
              The volume operates in conjunction with the slide guide, its resistance changing (analog) as the slide is moved.
              The ADF driver PCB reads these changes in resistance as the original size signal (WIDTH), and recognizes them as specific widths.
              To make sure that the original width volume (VR1) correctly detects A4R/LTRR and A5R/STMT widths, a special AB/inch sensor (PI4) is used inside the original tray; the sensor goes '1' (AB/inch identification signal) when the width of the original is 197 mm or more and less than 214 mm
              • blu3sky
                • Jul 2010
                • 25
                try to set off the auto oriented
