iRC 624: waiting....
  • iRC
    Summer trainee!
    • 96
    [Dead] iRC 624: waiting....
    Hi!
    We have one iRC 624, which doesn't work at all. When powered on, the device stays in waiting... -state. I've changed the "controller card" from side of the device, but it still keeps telling the same message. The controller card is a working one; it has been tested in other device. Is the controller card interchangeable? The device has been unused for quite a long time, could fixing unit cause this?
    -iRC
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    I newer work on this model but usually fixing unit cause this issue.Check in service mode for
    fixing temperature.
    COPIER>DISPLAY> ANALOG
    • iRC
      Summer trainee!
      • 96
      Actually this is just a plain printer unit. Same which is in CP-660, but without the scanner unit. I also suspect that the fixing unit is bad, since the device has been unused for about 1-2 years.
      • zoraldinho
        • Mar 2008
        • 5018
        I newer so this model in EU market.
        • iRC
          Summer trainee!
          • 96
          So, am I right with my thoughts? Are there any other known issues which might cause this symptom?
          • zoraldinho
            • Mar 2008
            • 5018
            -Service Mode: *28*
            -Fuser Count Reset Mode: 1001
            Fuser count reset mode is used when the fixing assembly is replaced. It may therefore be used either by
            the user or by the service person. Specifically, it is used to reset the fixing assembly counter after
            replacement, as when it has reached the end of its life.
            Check also Level 1 Items of Service Mode:
            DISPLAY/MISC: indicates the environmental conditions and a warning, if they are out of scope
            for guaranteed operation.
            TEST: executes various mechanical tests prepared as part of service mode of the
            engine being in use.
            • iRC
              Summer trainee!
              • 96
              Originally posted by zoraldinho
              -Service Mode: *28*
              Thanks. But as I said, this is just plain printer, so there's no scanner unit. Printer itself has a screen and few buttons for moving at the menu. I guess I'll be checking out the fuser when I have spare time.
              • vigour
                • Aug 2010
                • 1038
                I have never heard of this model but,( WAIT....), on other models is fixed by a system software reolad.
                • iRC
                  Summer trainee!
                  • 96
                  I'll check the fixing unit. Thanks for replying.
                  This model is old, but I want to fix it, since one of our customers has a CP660, and its printer unit has some bigger problems. They don't want to buy a new advance, so the salesman is offering them a "printer upgrade".
