irc4080 repeating image.
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    G'day,
    I have the irc4080 which had a new black drum unit about 1-2 weeks ago. Now its repeating the image in the NON feed direction.
    When printing in black mode A4LEF, everything is ok.
    When printing in colour A4LEF the black image is shifted 2-3mm toward the top of the page (the short edge). It is only occurring toward the rear of the print. Also still puts black where it is meant to. All other colours are where they should be laid.
    I haven't seen this problem before so any advice is very welcome.
    Cheers all
    Jonezy.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    post a scan image.
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      Originally posted by zoraldinho
      put a scan image.
      I would. Dont know how to. It asks for image url?
      • zoraldinho
        • Mar 2008
        • 5015
        Click on mark image and select from computer option then select basic.
        • charm5496
          • 2387
          Try swapping the two Sub PDRM-EF-A pcb's. If the problem moves from one color to another replace the failing Sub PDRM-EF-A pcb.
            • 16083
            Originally posted by jonezy999
            G'day,
            Cheers all
            Jonezy.
            On a (cross feed) direction only issue-
            Clear out the Registration Data stored in the DC Controller.
            To clear the data, perform the following.
            Enter Service Mode:
            in Level 2
            > Copier > Function > Clear > Reg/Clear.
            Highlight Reg/Clear and press OK.
            After performing the clear, reboot the machine and perform a Gradation Quick Adjust and then a Full Gradation adjust.
            ****Following the instructions above could prevent you from having to perform a DC-CON clear, and inputting all DC-CON values from the door label.
            • jonezy999
              just one copy??
              • Feb 2010
              • 952
              20110412170429101.pdf
              Thanks for all the replies. Will post an outcome later.
              • WOETC
                If I read the description of the error properly it sounds like a black laser issue.
                • jonezy999
                  just one copy??
                  • Feb 2010
                  • 952
                  Thank you all very much. Teckat, you are the man.
                  Performed REG/CLEAR and graduation adjust. Cured the initial problem. Graduation charts were just a little out. Clean of the transfer belt unit and machine is back in spec.
                  Cheers again,
                  Jonezy.
                    • 16083
                    Cheers again,
                    Jonezy.
