IRC3170
  • ARUN MISHRA
    • 80
    [Dead] IRC3170
    the main power switch on......... display lcd is blank .....and power led is on... no ration in the m/c //////////..ichek sdram ...help me.
    sigpicARUN KUMAR MISHRA
    Does the machine warm? up I would check reseat all boards in the main controller, replace ram.
    • charm5496
      • 2387
      did you try a new boot rom?
      could also be main controller.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        can you use RUI?
        • duckster
          There is another power switch !
          You probably have been switching the power switch on the right hand side of the printer !
          There is another power switch at the back of the printer on the right hand side !
          How do I know I just got caught out exactly like you have just been caught out on an IRC3170.
          Thats right lets have two power switches on a printer to confuse us.
          Hope this sheds some light on your problem !
          • teckat
            • 16083
            unplug dc controller connectors one at a time/
            power up printer each time u remove a connector
            • glasstec
              • Sep 2010
              • 25
              hi i had a similar fault and in the end its was the control panel.
