IR4570 Error 0007
  • alysson
    • 25
    IR4570 Error 0007
    Hi everybody,
    I got a trouble at IR4570. Error code 0007-0000, when machine takes more than 4, 5 copies the error appear and machine goes down. It jaming at fuser. Some idea? I haven't this machine service manual and I don't know the error codes. =/
  • ReproKev
    • 273
    I'm fairly new to those smaller machines myself but it looks like a fixing film error. Here's what the book says:
    E007 The rotation of the fixing film is faulty.
    0000 While the fixing motor is rotating,
    the marker signal is not detected for 6
    sec with the reading of the main
    thermistor indicating 100 deg C or
    more.
    Reset the condition in service mode:
    COPIER>FUNCTION>CLEAR>ERR.
    Replace the main thermistor. Replace
    the DC controller PCB.
    • kuby
      • Oct 2007
      • 1409
      It is probably the fuser film, seen a lot of these. You may have to replace the film if it is torn on one side. (usually on the left side - side opposite the sensor)
      • alysson
        • 25
        ReproKev, do you have the code of this thermistor?
        • jiongpao
          • May 2009
          • 413
          try to put some high-temp grease inside fuser film. If the problem still occur change fuser film
          • dharani
            • 39
            its a fixing film rotation is faulty, remove the film and apply more greece and fix it,...
            practically i have done the above to solve the issue, try it............
