IR5000 : How to force to copy/print ONLY face up
  • mrfixit51
    Lead Service Technician
    • 1975
    Originally posted by andalasgt
    Thank you, I will learn it. ...
    These parts are needed to rebuild the fuser exit/inversion area to get rid of ripped legal length copies from slowing up in the inversion process.
    FB6-5892-000 Roller
    FB6-5895-000 Roller
    FB6-5896-000 Roller
    FS7-0660-020 1-way Gear
    FS7-0664-020 1-way Gear
      • 16083
      here are other locations of parts mrfixit51 mentions in his reply
      #97=FB6-5896-000 /Shaft, Roller
      #114=FS7-0660-020 /1-way Gear
      #100=FS7-0664-020 /1-way Gear
      #300=FB6-5892-000 /Roller
      FB6-5895-000 Roller,is shown on other pic above
      • andalasgt
        • Oct 2010
        • 49
        It seems quite difficult to disassembly it, but i will try to do it this weekend.
        Thank you for your description.
        • mrfixit51
          • 1975
          #19
          It is not really that difficult, just remove the fan assembly in the front, the drive motor on the rear of the assembly, and shields as necessary...
