Need help with canon ir330 adf feeder A1 service manual
  • ctech81
    • 10
    I need to do an adjustment to the pressure of the feeder unit that picks up the paper. If any one has the manual I really could use the help.
    Thank you
    Ctech81
  • logonjim
    • 136
    What do you need to adjust the feeder unit for? normally changing out tyres and belts cure any feed problems. Is it double feeding on you? or not feeding at all?
      • 23010
      You'll need a spring gauge to do it right.
      And if you do it wrong it will stop feeding altogether. My recommendation is to just change out the tires first. =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        I've got the manuals.
        • JustManuals
          • Jan 2006
          • 9838
          knock yourself out.
