OPC NP-6330 replacement
  • markoz
    Hello,
    Did anybody try some replace for NP-6330 single drum or drum unit??? It seems to me that it is compatible with NP-1550 but I didn't try it. If anybody try it please help.
    • 23010
    The part # for the NP-6330 drum unit is 1322A002AA.
    The closest one might be the NPG-1 for NP-2020
    Another choice might be the drum & blade only kit for the NP2020. They look very similar, but I've never tried substituting.
    For myself, I would just order the NP-6330 drum & get it over with.
    • markoz
      I know that is the best solution (to replace it with original part) but believe it or not i can't find original part (drum and cleaning blade for 6330). They give me a substitution solution 6030 and 1550. I know that 6030 is not the same but for 1550,2020 I'm not sure. I will exchange it if is solution, i expect that copy will be bad because of incompatibility with toner but i will try with NPG-1 toner too, if drum or drum unit can be replaced. Thank you for replay.
      • logonjim
        • 136
        np 6330
        yes i have used both types of drum in the machines i think you have to change to metal plate on the front and they will fit .The quality is not as good as when uses the original drum tho and some adjustments need to be made for quality
