imagerunner 3100 itb
  • acsolutions
    • Jun 2010
    • 519
    Hello, can someone tell me how to remove the itb without damaging the belt.
  • BIMAN CHANDRA NATH
    • Apr 2011
    • 42
    If you have the service manuals of irc 3100 then go through it and you will not face any problem to change the itb
    • charm5496
      • 2387
      Not a job for the untrained user. There is a lot of disassembly involved with this process and even then you have to be careful removing it!!!
      • acsolutions
        • Jun 2010
        • 519
        Yes I am canon trained, though by the question it seems as I am not! I ran across a customer with a c3100 with a copy quality issue and wants me to address it at a later date. I believe it is a drum assembly but just looking at my options. I am trained on the 5800/6800 so they seem to be similar.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          If you say so,with manual can't be a problem.
          • acsolutions
            • Jun 2010
            • 519
            I also have NAVI and checked for the procedure but does not have it, I need the CD to be able to access that information. Is the cleaning blade attached to the ITB or does it slide out? Can I lube the blade or does it go in dry?
            • acsolutions
              • Jun 2010
              • 519
              Thanks canon tech, I get an adobe error message saying, file is damaged and cannot be repaired. is there another way you can send it to me, I would be very grateful. Thanks
              • acsolutions
                • Jun 2010
                • 519
                Would you look at that! Thanks, canon.tech, I am feeling a little more at ease.
