I have see pinched wires cause this issue on these 3220 panels/
be aware in future
be aware in future
130 | FG6-8941-030 | 1 | CONTROL PANEL ASSEMBLY | JPN | |
130 | FG6-8933-030 | 1 | CONTROL PANEL ASSEMBLY | USA | |
130 | FG6-8934-030 | 1 | CONTROL PANEL ASSEMBLY | MSN,SSX,QLZ,SLZ,TLZ, UKF,JCK,JBC,JBQ,JCJ,\nJAF |
130 | FG6-8935-030 | 1 | CONTROL PANEL ASSEMBLY | SSY,RLZ,RQZ,JCL,RQY | |
1 | FB5-2172-000 | 1 | KEY TOP, START | ||
2 | FB5-3698-010 | 1 | KEY TOP, RESET | ||
3 | FB5-3699-000 | 1 | KEY TOP, POWER SUPPLY | ||
4 | FB5-3728-000 | 1 | KEY TOP, ENERGY SAVE | ||
5 | FB6-3944-000 | 1 | WINDOW, LAMP | ||
6 | FB6-3945-000 | 1 | WINDOW, LAMP | ||
7 | FB6-3946-000 | 1 | KEY TOP, STOP | ||
8 | FB6-3947-000 | 1 | SHEET, ELECTROSTATIC | ||
9 | FB6-3951-000 | 1 | KEY TOP, COUNTER | ||
10 | FB6-3949-000 | 1 | KEY TOP, NUMBERS | ||
11 | FH2-7037-000 | 1 | CABLE, FLAT | J1112 | |
12 | FK2-0329-000 | 1 | ANALOG TOUCH PANEL UNIT | J1114 | |
13 | FG3-2357-000 | 1 | CONTROL PANEL KEY PCB ASSEMBLY | ||
14 | FG6-8938-000 | 1 | CONTROL PANEL CPU PCB ASSEMBLY | ||
15 | FG6-8939-000 | 1 | C. PANEL INVERTER PCB ASSEMBLY | ||
16 | FG6-8936-000 | 1 | LCD CONTROL PANEL UNIT | J2,3 | |
17 | FG6-9164-000 | 1 | CABLE, C. PANEL INVERTER | J1,1113 | |
18 | FG6-9165-000 | 1 | CABLE, C. PANEL KEY, A | J1111,1117 | |
19 | FG6-9166-000 | 1 | CABLE, C. PANEL KEY, B | J1110,1116 | |
20 | FB6-3953-000 | 3 | PLATE, GROUNDING | ||
21 | FB6-6213-000 | 1 | LABEL, PAPER SET CAUTION | ||
501 | XB2-8300-607 | AR | SCREW,W/WASHER,M3X6 | ||
502 | XB4-5300-807 | AR | SCREW,P,M3X8 | ||
503 | XB1-2300-607 | AR | SCREW,MACH.,TRUSS HEAD,M3X6 | ||
504 | XB4-5301-007 | AR | SCREW,P,M3X10 |
