I have a customer who has a deletion on the outboard side of their prints. The copier is a canon ir1023. Copies and prints are bad. I cleaned the charge roller. The developer is covering the mag roll. Could the laser be the problem? Thanks, Roger.
ir1023 deletion
look at this test chart/ then describe your CQ direction issue (outboard side ?)
The Color of the line arrows/match description information
TESTCHART223.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
The deletion is in the paper feed direction. About 1 inch of faded print on the side of 81/2 x 11Comment
