Canon 3220 Lower Fuser Temp?
  • NeonDoorMedia
    • May 2011
    • 17
    Can anyone explain how to lower the fuser temperature on a Canon 3220?
    Thank
    -Sylvia
  • doktor
    • 214
    irc3220n-sm.pdfHere you have.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5011
      Why do you need lower fixing temperature at the first place.Are you tech ore user.If you really Sylvia from the pic,I give you new fuser for free.
      • NeonDoorMedia
        • May 2011
        • 17
        User and yes I'm the one in the pic. I just can't seem to find a Canon tech in the area that can fix anything for me, so I've taken it upon my self to do it.
        Thanks for the help
        • teckat
          • 16083
          in service mode
          COPIER>OPTION><BODY>TEMP-TBL
          Used to change temperature table for fixing temperature regulation.
          Setting 0: Use normal temperature-regulation tablePower Save Functions
          1. Standby Mode
          In standby mode, the machine is in operation or is ready to operate, with all its parts
          supplied with power.
          2. Power-Save Mode
          The term “power-save mode” is used generically to refer to the following modes, in
          which the machine is supplied with power differently than it is in normal mode: powersave,
          low-power, sleep. A shift in the direction of ‘present power-save mode’ to ‘lowpower
          mode’ and then to ‘sleep’ mode occurs automatically.
          • Power-Save Mode• Low-Power Mode (factory setting)
          This mode conforms to the standards under Energy Star.
          Shift: A shift is made only in response to the passage of time (auto low-power shift time) selected in user mode.
          Description: • Sleep Mode (sleep mode 1 or sleep mode 2)
          Shift: A shift is made in response to the passage of time (auto sleep shift time) specified in user mode or in response to a press on the control panel software power switch.
          Description: In sleep mode 1 (relatively higher power consumption), the fixing assembly
          is totally deprived of power. The DC controller PCB, however, remains supplied with power.
          In sleep mode 2 (relatively lower power consumption), on the other hand, the printer unit (including the fixing assembly) remains OFF; the main controller PCB is supplied with all-night power.
          • V-P
            • Apr 2011
            • 679
            Thanks for the help
            I would like to offer a NEW FUSER TOO !!!!
