Irc5185
  • Dzeak21
    • Oct 2007
    • 43
    Irc5185
    Someone told me to try a rcon clear for anfax issue and having problems with adf now machine will copy from glass but when trying to make a copy though adf it reads jam but there isn't one hopefully i didn't screw it up.
  • teckat
    • 16083
    u need to put back the RCON settings >>
    did u print out the P PRINT settings/or do u have the original settings from machine ??
    RCON service label settings= (label is attached behind reader unit front cover)
    Enter the settings for the following items in service mode:
    (1) standard white plate white level data
    COPIER>ADJUST>CCD>W-PLT-X,Y,Z
    Look at cover label settings for these below
    (a) image read start position adjustment (x direction; for fixed reading)
    COPIER>ADJUST>ADJ-XY>ADJ-X
    (b) image read start position adjustment (Y direction; fixed reading)
    COPIER>ADJUST>ADJ-XY>ADJ-Y
    (c) shading position adjustment (for fixed reading)
    COPIER>ADJUST>ADJ-XY>ADJ-S
    (d) feeder mode main scanning position adjustment
    COPIER>ADJUST>ADJ-XY>ADJ-Y-DF
    (e) ADF stream reading CCD read position adjustment
    COPIER>ADJUST>ADJ-XY>STRD-POS
    (f) CCD unit-dependent RB/GB sub scanning direction color
    displacement correction value
    COPIER>ADJUST>CCD>CCDU-RG/GB
    (g) CCD unit-dependent RG/GB sub scanning direction color
    displacement value at shipment
    COPIER>ADJUST>CCD>FCCDU-RG/GB
    (h) auto gradation adjustment target value
    COPIER>ADJUST>PASCAL>OFST-P-Y,M,C,K
    before someone tells you to clear anything, make sure u know how to print out the machine settings-
    ***person who told u to clear settings, without printing out P PRINT SETTINGS is a JERK
    This machine also stores ADF related data on the Reader Controller. Be sure to adjust the following in service mode for the feeder.
    FEEDER > ADJUST > DOC > STOP
    FEEDER > ADJUST > LA-SPEED
    FEEDER > FUNCTION > SENS-INIT
    For A/B size FEEDER>FUNCTION>TRY-A4 and TRY-A5R
    For INCH size FEEDER>FUNCTION>TRY-LTR and TRY-LTR-R
    COPIER > FUNCTION > CCD > DF-WLVL1.
    Place a sheet of paper in the Feeder and run FEEDER > FUNCTION > CCD > DF-WLVL2
    Enter Level 2 Service Mode, COPIER > OPTION > BODY > SENS-CNF > set to 1
    • Dzeak21
      • Oct 2007
      • 43
      I got it just had to do a feeder initialize took care of it
