We have an Ir-3300i in the field and the copier is stuck in scanning...
Copier turns on fine and goes to ready mode in copy, when you try to make a copy from the Feeder or glass and you press the start key, the copier just stays stuck with the message on the display "scanning".
Never gives a code or jams. It's just stuck on that message. Only way to clear it is to turn off the copier and back on.
I have replaced main board and display. Any other suggestions?
