Ask about iR3300 speed
  • toantam
    • 63
    [Misc] Ask about iR3300 speed
    Dear somebody help!
    I bought a iR3300, when I buy the boss told me machine work 33 sheet on A4. But when I check machine just work 22 sheet on A4. Maybe something wrong.
    Plaese give me some idea. How to make this machine return to 33 sheet on A4.
    Thank you so much.
  • charm5496
    • 2387
    Re: Ask about iR3300 speed
    sounds like you have an IR-2200...22 ppm. Hit counter check and see what the model and serial number says.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Also check if you have plain paper selected.
      • teckat
        • 16083
        U can't tell a book by the cover
        Model EMBLEM on door means nothing-
        Overseas Third party sellers swap doors to deceive customers/
        in USA you go to jail for that-
        ------------iR3300--------iR2800--------iR2200
        Direct A3--16cpm--------16cpm--------16cpm
        A4---------33cpm--------28cpm--------22cpm
        A4R-------18cpm--------18cpm--------18cpm
        A5--------18cpm---------18cpm--------18cpm
        A5R-------18cpm--------18cpm--------18cpm
        Reduction A3 → A5R (50%)-----18cpm-----18cpm-----18cpm
        A3 → A4R (70%)-----18cpm-----18cpm-----18cpm
        Enlargement A4R → A3 (141%)--16cpm----16cpm-----16cpm
        A5R → A3 (200%)---16cpm------16cpm----16cpm
        Except when paper is fed from the stack bypass.
        • teckat
          • 16083
          Also>Check your Serial number on machine plate
          iR2200
          100V 50/60Hz--LSH00001-
          220V 50Hz----PRC00001-
          120V 60Hz----NSQ00001-
          220V 50Hz----PRD00001-
          120V 60Hz----MPC00001-
          240V 50Hz---QDR00001-
          240V 50Hz---RDN00001-
          220V 50Hz---SCP00001-
          220V 50Hz---TDF00001-
          220V 50Hz---UGU00001-
          iR3300
          100V 50/60Hz--LSM00001-
          220V 50Hz----PRH00001-
          120V 60Hz---NSS00001-
          220V 50Hz---PRJ00001-
          120V 60Hz---MPD00001-
          240V 50Hz---QDT00001-
          240V 50Hz---RDP00001-
          220V 50Hz--SCX00001-
          220V 50Hz--TDJ00001-
          220V 50Hz--UGW00001-
          • teckat
            • 16083
            If u don't see serial # listed when u hit counter check/
            go in service mode-
            1) Press the User Mode key ‘*’ .
            2) Press ‘2’ and ‘8’ on the keypad at the same time.
            3) Press the User Mode key ‘*’ on the control panel.
            select>>COPIER>OPTION>USER>CNT-DISP
            and Use it to enable or disable the indication of the serial number in response to
            a press on the Counter Check key.
            Settings 0: enable (default), 1: disable
            Seller may have it set at "1"
            • Dedy.P
              • 67
              Originally posted by toantam
              Dear somebody help!
              Thank you so much.
              just upgrade the main control, then the machine will run 33 sheet on A4
              • teckat
                • 16083
                Why spend more money>
                what about cutting the throat of the person who deceives you, if that is the case.
                • charm5496
                  • 2387
                  You would have to chance out the Serial number and counter board in order to accomplish this.
                  • Canuck
                    Tech Specialist
                    • 1713
                    No it wont. Same part number for 22,28 and 3300
                    • teckat
                      • 16083
                      Serial Number pcb. works in conjunction with the Main Controller and the Counter Pcb.
                      that is where the speed of similar models is controlled
                      The Serial Number PCB's are restricted. The Serial Number PCB can only be obtained by contacting the Canon Technical Support Hotline
                        • 23009
                        Swapping around these serial number PWB's is an excellent way to make your MFP into a doorstop. Don't do it. =^..^=
                        • toantam
                          • 63
                          My machine use 120V and I saw on the rear side this serial number: MPG 63013
                          The front side iR 3300, So as you said I have to change serial number PCB and counter PCB or Main controller PCB.
                          Thanks for your suggestion.
                          • charm5496
                            • 2387
                            MPG is the serial prefix for an IR-2200. They switched the front door on you.
                            • teckat
                              • 16083
                              CALL A COP !!!!!!!
                              OLD saying_ "Sucker born every minute"
                              How are u timekeeping this printer ??
                              Canon test are from a single piece of paper placed on the glass/with no sorter attached/and paper pulled from a cassette.
                              You can not get a serial #PCB Board
                              / they are only sent by CANON
                              Counter Memory, Serial Number and Main Controller PCBs work as a set and are considered the “Soft Counter Circuit”. The Counter Memory PCB is electronically stamped with the serial number from the Serial Number PCB.
                              Neither the Counter Memory PCB nor the Serial Number PCB can be swapped to other equipment. The Counter Memory PCB keeps track of the total count, which cannot be erased or changed. The service counters are retained by the Main Controller. These counters can be reset manually through service mode.
                              go in service mode-
