Canon c3200 and x3e-01 not able to connect to network
  • dewsangam
    Hello everyone i spent all day yesterday trying to find a solution to this problem
    I just bought a used canon C3200 that come with a X3e-01 SN JFN00341, but could not get it to connect to my network..
    I have an ATT 2wire router, and the printer is connected directly to the router. i have 1 wired pc, 2 wireless laptop an a wireless imac connected to the same small office network. i want to use the printer on the network, but could not see it. i tried everything on this board but no luck yet. any help will be highly appreciated. thank you
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon c3200 and x3e-01 not able to connect to network
    Are you a tech?
    • charm5496
      • 2387
      did you configure the imagepass for your network? Is the imagepass connecting to your copier and coming to a ready state?
      • dewsangam
        No am not a tech, just an end user.
        Yes the imagepass is connected to the copier and am not sure what you mean by ready state, but it comes on when i power it up but no configuration menu on the printer screen.
        • zoraldinho
          • Mar 2008
          • 5015
          Read carefully PDF.............f-im-6126-010.pdf
          • charm5496
            • 2387
            ftp://89.223.26.2/Distributive/-=%20...unit-d1-sg.pdf
            this guide will help as well.
            • dewsangam
              I think i need to reinstall the system software and if i do where do i get one because am not see any printer tab on the screen. all i see is copy, mailbox and scan tabs and there is no arrow for more tabs off the screen
              • charm5496
                • 2387
                you have to go into the machines service mode and turn it on. See page 3 of the document that zoraldinho posted. * (2,8) * to get in there. copier>option>body>IMG-CONT to a '3' restart the machine
                • dewsangam
                  The problem i having is am not even seeing the copier>option.
                  All i see when i power up the machine is a copy, mailbox and scan tab and the copy tab is highlighted. and few other buttons, direct, copy ratio, finisher, paper select, two sided, interrupt, special features etc.
                  • dewsangam
                    I got the printer with the imagepass already install and connected. just not seeing and configuration screen for it.
                    • zoraldinho
                      • Mar 2008
                      • 5015
                      Read again slowly Charm's last post.
                      • charm5496
                        • 2387
                        service mode...you have to go into service mode...reread the post from an hour ago.
                        • dewsangam
                          First of all i wanted to say thank for being patient with me. I was able to get into service mode by pressing additional functions on the key pad>2,8>copier>Option>int-face>img-count. this where i'm stock. i see 3 and arrow ( 3 ) {0 5}. i press 3 on the keypad but nothing happen i press a different number then the (3) changes to that number. i changed it back to 3 press ok and restated my machine then what?
                          • charm5496
                            • 2387
                            touch the ING-CNT and change to a 3. Hit OK to store and then reset 3 times to exit.
                            • dewsangam
                              Now i think am getting somewhere. i restated the maching. now i can see the printer tab but when i press it, i get printer status/setting button, press that, i get the wait a moment screen. i waited but nothing happen checked all the cables everything seems to be connected.
