paper is not correct , change paper messege
  • adel_nathan
    • Jul 2011
    • 103
    [Error Code] paper is not correct , change paper messege
    hi every body
    i have canon photocopy machune model IR2020
    from 2 days appear messege when i using 1st cassette
    " paper is not correct , change paper "
    i do that :-
    1- change paper size frome A4 to A4r to A3
    2- change paper type from plane to recycle to heavy ot couler ...act
    3- reset machine from service mode " cleaer , all "
    all these and the messege same
    note when i using 2nd cassette it's normall copy but it's slower than befor
    please help
    thanks
  • charm5496
    • 2387
    Re: paper is not correct , change paper messege
    do you get a jam with this message? There is a gear that was updated on the cassette feed unit that was updated for this issue.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5012
      ir2020-018.pdf
      • charm5496
        • 2387
        Originally posted by zoraldinho
        [ATTACH]10795[/ATTACH]
        that's the one!!! Pain in the rear to get to those feed units!!!
        • Mikey
          • Sep 2009
          • 54
          Thank you.
