A-SI Drum Cleaning Powder Material Change
  • teckat
    • 16083
    [CQ] A-SI Drum Cleaning Powder Material Change
    A-SI Drum Cleaning Powder Material Change/
    General B/W and Color Equipment / All
    The manufacture will discontinued use of the SHOROX A31 A-SI Drum Cleaning Powder Material (Brown). In its place the manufacture has recommended the use of FO#6000 Drum Cleaning Powder Material for all A-SI Drums.
    see pdf>>>[ATTACH]10887[/ATTACH]
  • autan
    • 7
    Re: A-SI Drum Cleaning Powder Material Change
    teckat,plese give me some information how to repair A-SI Drum from damage or scratch?
    • teckat
      • 16083
      the Power is for cleaning/won't remove scratches
      I have used Brasso cleaner on Selenium drums or Car Wax for light scratches
      • charm5496
        • 2387
        Same here. We have also used a product called "putz" which is a cleaner for press rollers and works pretty good on these drums as well.
        • vigour
          • Aug 2010
          • 1038
          Somewhere in the archives some guy says he puts clear nail polish on the scratch.
          His explanation: It is easier to get away with a small blank spot than a small black spot.
          some day I will try it.
          • teckat
            • 16083
            have see KRAZY GLUE used
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5015
              Don't if you not shore!
              • jacky_kuo
                • Aug 2011
                • 54
                Sorry , Teckat ,
                I have a question ??
                This is how much capacity "FO#6000 Drum Cleaning Material (Grey)" bottle ? (FY9-6024-000)
                Could you recommend cleaning drum with a frequency??
                If i often cleaning,
                What of the drum bad influence?
                • teckat
                  • 16083
                  Originally posted by jacky_kuo
                  Sorry , Teckat ,
                  amt in bottle not known
                  Clean every 500,000 prints
                    • 23009
                    This used to work on the Selenium Tellurium drums of many days gone by, because those machines (the early Mita's, i.e DC-131) had no cleaning unit or blade. There was a cleaning corona wire, that would release the charge from the drum after each cycle, then pull any residual toner back into the developing unit. There was no physical contact of a blade to the drum.
                    When this fix was attempted on later machines with cleaning blades, I discovered that it didn't work so well. The drum surface has to be perfectly smooth to clean properly, and that small lump of nail polish leaves a teardrop shaped comet-trail of toner behind after every revolution.
                    Now, ASi drums are considerably more durable than the Selenium Tellurium drums that I experimented on, so a tech could conceivably fill a scratch, then somehow buff the resulting surface smooth. That would never have worked on those earlier drums. I single fingerprint could be the end of a drum. =^..^=
