Post Script and CorelDraw font issue
  • Ralph1
    • Jul 2011
    • 19
    Running Canon 2620
    Apologies if this shouldn't be posted here.
    Now using Post Script driver with good colour matching.
    Using CorelDraw X5 sp 3 and all my fonts print out really heavy on the black, they almost look Bold. Have tried all settings. All print fine in other applications.
    Has anyone else had this issue?
    Thanks,
    Ralph.
    • 23008
    Re: Post Script and CorelDraw font issue
    Does this occur when you're printing in color, but not monochrome?
    Color prints create black using Cyan, Magenta, Yellow, and a little Black toner, also referred to as composite black.
    Monochrome prints create black using Black toner only.
    I think that you're noticing that composite black produces a much thicker layer of toner on the page than monochrome black. I'm not sure that you can do anything much about this. Let's see if one of the Canon guys has an opinion on this. =^..^=
    • Ralph1
      • Jul 2011
      • 19
      Hi,
      Thanks for the reply.
      Yes it also does it in both colour and mono, also with text only, even though I set the text to only be comprised of black(K), this happens whether using the cmyk or rgb pallate colours.
      Selecting plain or heavy stock also makes no difference.
      My thoughts are that it's related to the CorelDraw x5 application not dealing with Post Scipt accurately.
      Any comments would be much appreciated.
      • vigour
        • Aug 2010
        • 1038
        No one I know likes to work with accounts that use Coreldraw.
        I hear it causes problems.
        • Ralph1
          • Jul 2011
          • 19
          Hi folks,
          Been helped to find the answer.
          Had to do with my ignorance on colour management.
          Resolve was to apply these settings.
          1. Primary Color Mode : CMYK
          2. Rendering Intent : Perceptual
          3. Color Engine : LCMS
          Now all's printing fine.
          Thanks for all the replies and willingness to help. Much appreciated,
          Ralph.
