Canon iRC3200 waste toner leaking
  • apollo
    • Mar 2008
    • 176
    [CQ] Canon iRC3200 waste toner leaking
    HI,
    I have Problem On iRC3200 Waste toner leaking onto the guide plate below the itb cleaning blade
    and speckling spots on copies.
    When i remove the cleaning blade assembly and waste toner feed collector there pile of waste toner below the guide plate.
    I have changed new blade assembly, itb belt, new itb belt assembly, but still get same problem.
    Any input would be appreciated Thanks
  • apollo
    • Mar 2008
    • 176
    Re: Canon iRC3200 waste toner leaking
    • apollo
      • Mar 2008
      • 176
      Some waste toner does go into the waste toner bottle and pile of waste in the copier,
      I left door open and actuated the door and the waste toner coil is turning, i can se the end shaft turning.
      • apollo
        • Mar 2008
        • 176
        The racking machanism was stipped down & fixed, as the gears were not meshing all the time between it belt assembly
        and the toner waster collector cocksrew gear.
        I hope this may help anyone with similar fault.
