ir1310 accordion jam at exit
  • luodal
    • Aug 2025
    [Jamming] ir1310 accordion jam at exit
    I'm unable to remove a piece of paper teared while taking out an accordion jam at the exit rollers.
    It seems that i must dissassemble the whole machine, to get beneath the delivery roller. any tips on how to proceed.
    thanks.
  • teckat
    • 16083
    Re: ir1310 accordion jam at exit
    thanks.
    Removing the Fixing Assembly
    Click on picks for view 1>10
    GOOD LUCK
    COVER.JPGFIX.JPGDELIVERY COVER.JPGDELIVERY UPPER COVER_Delivery Rear Cover.JPG
    • luodal
      Thank you very much for your quick and complete answer. It is like I thought it will be..... Difficult and time consuming. I hope I can Complete the task successfully.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        All steps look good, except the first one, there is no reason to pull that steel plate off of the rear of the copier. Remove the covers on the left side as described, the doc glass, access the rear screw on the fuser down thru the hole hidden under the black cable guard in the optics, moving the bed til both holes line up. Remove screw from control panel as described, hold the op panel, still connected but out of the way to get the 2 front mounting screws on the fuser. Disconnect the electrical connectors, and wiggle the fuser out of its mounting place.
        I suggest you bring a new fixing film and pressure roller with you, as you do not want to go to this trouble to remove a jam, and have it recur from worn parts, the pressure roller coating wears out at the ends and causes the lead edge corners to stick down. When it gets bad enough, the paper sticks to toner deposits on the worn roller. Or pop for a new fixing unit altogether...
