Canon iR5020 Stapler
  • rlbass
    I have a Canon iR5020 with a finisher. I have the printer shared via a Windows 2003 cluster server. The users are able to staple when making copies locally, but the option is grayed out when printing documents from a PC.
    I am using the latest driver from Canon's website (PCL 5e for Vista and 2003 Server) for the printer, is there a seperate driver for the finisher? How can I enable the ability to staple documents when printing from a remote PC to this printer/copier?
  • yourownfree
    • Dec 2007
    • 474
    stapler
    go to device settings>get device status> apply
    you should see the finisher after you do that.
    • yourownfree
      • Dec 2007
      • 474
      its one of the print driver tabs "device settings"
      • kwazimoto
        • Jan 2007
        • 199
        stapler
        if the canon software is not loaded on the machine to get device status go to the print driver and tell it it that a staple is installed in the finishing section of the driver ..
          • 22997
          It can be configured manually in the print properties. The idea is to get the driver to know all the available accessories.
