Canon ir c4080 - fuser parts
  • kuby
    • Oct 2007
    • 1409
    Has anyone found a source for the heat roller and press roller belts for the c4080 fusers? Wow at $1400, would like to try and rebuild one.
  • londonboy
    • Jul 2011
    • 10
    Re: Canon ir c4080 - fuser parts
    These are a nightmare to rebuild!!!, These fusers are sh*t, they grumble and then die with errors, before there get there, some small gears go, but thats the only thing worth replacing..............so over complicated.........typical canon.Good luck in your rebuild
    • ikon01
      • Apr 2011
      • 53
      londonboy is spot on,really not worth the stress.these fusers will have you going round in circles.friggin nightmare!!
      • teckat
        • 16083
        when we had to re-build in field, we had more issues during the inspection, broken gears / fried sensors/ etc.
        was a nightmare because techs failed to follow the Canon info procedure for E007
        the belt tear is not the only headache on this unit
        old rebuild & inspection Tech Pubs>>>>>
        u probably have seen these before
        Fixing Unit_TP07-168.pdf5185_007 Checks.pdfFixing Unit Checks TP07-2.pdf
