IR3570 Scanning
  • Northwestservice
    • Jan 2011
    • 140
    IR3570 Scanning
    We rented a Ir3570 (without) meaps licence. told customers IT people that you can pull scan with software that has an aquire function. IT people tell me they cant find a free software that works. i told them they need to purcahse a full version of something like adobe. they insist that the scanning function does not work any suggestions as to what can be done?
  • spectraindo
    • May 2008
    • 313
    Re: IR3570 Scanning
    There are many free softwares for scanning, they came bundled with the purchase of a scanner like Adobe Photoshop Elements (a cheap version of Photoshop).
    Tell the IT people to install canon Network Scangear and discover the machine, this is the TWAIN driver for Canon iR machines.
    • charm5496
      • 2387
      Re: IR3570 Scanning
      they need to download and install NWSG for the pull scanning to work and you can use freeware to open the docs that you create.
      Color Network ScanGear v2.23
      here is a link to the manual and software.
      • spectraindo
        • May 2008
        • 313
        Re: IR3570 Scanning
        Color Network Scangear will not work with this machine, it is only black and white.
        Go to the Canon website and download Network Scangear.
        • charm5496
          • 2387
          Re: IR3570 Scanning
          grabbed the wrong link sorry.
          Network ScanGear v2.21
          here you go
          • Simons
            • Jun 2008
            • 490
            Re: IR3570 Scanning
            office 2003 = microsoft office tools / MS office tools for document scanning. office 2007 scanning http://services.pepperdine.edu/it/co...ng-off2007.pdf
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Re: IR3570 Scanning
              I researched free scanning software, and found the following, here is it's description from SourceForge.net
              ScanTWAIN Updated 2011-02-23[/
              "ScanTWAIN is an Open Source TWAIN production quality scanning application based on QT 3.x. ScanTWAIN allows for duplex scanning from automatic document feeder (ADF) based scanners via TWAIN. "
              Coupled with the scangear, you should have a solution...
              Download ScanTWAIN from SourceForge.net
              • teckat
                • 16083
                Re: IR3570 Scanning
                SourceForge
                -Banned countries and controversy
                In its terms of use,SourceForge states that its services are not available to users in countries on the sanction list of the U.S. Office of Foreign Assets Control (including Cuba, Iran, North Korea, Sudan and Syria). Since 2008, access to the secure server (used for making contributions to the site) was blocked for people from those countries. As of January 2010, all access including downloads is blocked for those users. This means that all people whose IP addresses appear to belong to those countries are prevented from using the site.
                These restrictions have drawn criticism as being counter to the free software movement, the open source software movement and the principles of making software available to all without discrimination.
                • anothertech
                  • 1771
                  Re: IR3570 Scanning
                  I use irfanview, it's free and easy to use.
                  IrfanView - Official Homepage - one of the most popular viewers worldwide
                  • mrfixit51
                    • Oct 2008
                    • 1975
                    Re: IR3570 Scanning
                    I gave it a try, but the most popular file format is not supported,, will not create .pdf's
                    • Northwestservice
                      • Jan 2011
                      • 140
                      Re: IR3570 Scanning
                      okay we downloaded the net work scan gear form the eurpoe site its in german? when we use discover it finds the ip address but says it is scanning is disabled?
                      • teckat
                        • 16083
                        Re: IR3570 Scanning
                        here is the ENGLISH link>Network ScanGear v2.21
                        Make sure Nw-scan is set to 1 in service mode and Enable dedicated Port under Additional Functions>System Settings> Network Settings is set to ON-
                        If you are using Network ScanGear for the first time after installing it, the network scanner to be used must be selected with the ScanGear Tool. The Network ScanGear driver cannot be started at the same time as the ScanGear Tool. If the ScanGear Tool is running, close it.
                        Network ScanGear is started by accessing it from a TWAIN compliant application as follows:
                        1. On the imageRUNNER-iR copier, press the Scan button. Press Online.
                        2. On the PC, start the TWAIN-compliant application.
                        3. In the application, select Network ScanGear as the scanner to be used. In the application, choose the command that selects a scanner, then select Network ScanGear in the dialog box that appears. After doing this operation once, there is no need to repeat it.
                        4. In the application, choose the command that starts scanning operation (for example, "Scan New" or "Acquire").
                        Did u re-boot after install of ScanGear ?
                        Look Here>http://www.copytechnet.com/forums/ca...-scangear.html
                        • Northwestservice
                          • Jan 2011
                          • 140
                          Re: IR3570 Scanning
                          i want to thank all who replied to this thread.....my machine is up and online now it is just the customer using a software that will work for them THANK YOU!!!
                          • teckat
                            • 16083
                            Re: IR3570 Scanning
                            Great~~~~~~~~~~~~~~~~~
                            Final Solution Was
                            • charm5496
                              • 2387
                              Re: IR3570 Scanning
                              way to keep at it and solve the issue!!
