Ricoh tech need help on old Canon NP6030
  • Hadster
    • Aug 2011
    • 264
    [Jamming] Ricoh tech need help on old Canon NP6030
    Paper Jams out of tray 2 with new feed tires. It picks up the paper and goes in about 4 or 5 inches then stops. I know
    on a Ricoh if the tray is set to the wrong size it will cause this prob. but the tray is set properly. I'm guessing a clutch?
    Thank you for any help!!
    • 22999
    Re: Ricoh tech need help on old Canon NP6030
    Start by getting the jam codes.
    If my memory still serves, there's a small hole through the purple inner front cover right near the meter. Use an allen wrench or the like to press the push switch within the hole. When successful you'll get a "$" in the corner of the display. You'll enter 01, Start, (which is display), then you can scroll through the entries until you see "Jam", then Start. They'll look like "010C" or like that. Write down all the ones recorded, then come back.
    Any other old codgers, feel free to correct me. =^..^=
    • mjarbar
      I still have the giant wavy paper clip I straightened for the task!!!
      If you haven't already done it it is worth cleaning any of the vertical path rollers as well, I seem to remember a couple were fond of just sliding over the paper and not feeding, but yes once we have jam codes!!!
      • Hadster
        • Aug 2011
        • 264
        Thanks everyone, I will retrieve codes this monday 8/29.
        • ikon01
          • Apr 2011
          • 53
          just to add to what the other gents said.don't discount the feed clutch.they used to play up alot when we had them in the field.
