Black lines intermittently on copies. any suggestions.
Black lines on copies IR3225
Tags: 225, black, black lines, copies, copy count, glass, intermittently, ir3225, lines, lines on copies, sea, shorting, unit
Re: Black lines on copies IR3225
Developer or fixing unit or......pic!!If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
It's look like developer bias issue.If it ain't broke, don't fix it
run a D-GAMMA in service mode.
COPIER / FUNCTION / DPC / D-GAMMA
D-GAMMA measures the drums' resistance to optimize primary charge output. In addition, this procedure should be performed when installing a new drum-
Remove & re-seat the connector to the Laser
Glass & DF are poor but>
how are the NETWORK PRINTS ??????**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
