Creasing on trailing edge
  • Gerry Ross
    • Sep 2011
    • 7
    [Misc] Creasing on trailing edge
    Creasing output on trailing edge of A3 only (about 2 inches) on iR3025
  • TEC DOG
    • Sep 2011
    • 113
    Re: Creasing on trailing edge
    Service Mode > Copier > Adj > FX-FL-SP
      • 23009
      Are you talking about pin-wrinkles, like moist paper? Especially on legal, or ledger, or duplex? Once you've tried fresh paper, take a look at the fuser. =^..^=
      • Gerry Ross
        • Sep 2011
        • 7
        No plain old 80gsm A3
          • 23009
          And you tried fresh, new, wrapped paper? =^..^=
          • Gerry Ross
            • Sep 2011
            • 7
            Its not damp paper
              • 23009
              Originally posted by Gerry Ross
              Its not damp paper
              I'll take that to mean: "No, I haven't tried that. But I'm not going to try that."
              Good luck. But if I were you, I would start with the simple things first. =^..^=
              • teckat
                • 16083
                change the value of FX-FL-SP in service mode to +3.
                • ikon01
                  • Apr 2011
                  • 53
                  Ive had this fault for couple of weeks now.I replaced the fuser because it was in a state,replaced the delivery assy and drive motor with no joy.Spotted this thread yesterday and popped back today.The adjustments worked a treat.
                  Thanks gents
                  • TEC DOG
                    • Sep 2011
                    • 113
                    • teckat
                      • 16083
                      The Dude.jpgyeah'
                      • Steve Baker
                        • Aug 2011
                        • 22
                        Clean up all fuser bearings... if needed fit new Silicon sleeve... and the final cure which i have had many successes with.. replace lower pressure roller. one thing for certain... it is fuser related! good luck mate..
                        Steve.
                        • Steve Baker
                          • Aug 2011
                          • 22
                          Steve.
                          there is also a further adjustment you can make... service mode 2 - Adjust - Fixing - change FX-FL-SP to +3
                          (I'TS A FINE ADJUSTMENT FOR FIXING FILM SPEED)
                          Enjoy...
                          • teckat
                            • 16083
                            Enjoy...
                            poster already used the previous suggestions / with success
                            read through the post
                            • Steve Baker
                              • Aug 2011
                              • 22
                              Just finding my feet with this site... former Smarka member...
                              Cheers Teckat.
                              Steve...
