Canon imageCLASS MF4150 scanner lamp (E225 and consistent behavior)
  • cat /dev/urandom | lpr
    • Jun 2025
    [Error Code] Canon imageCLASS MF4150 scanner lamp (E225 and consistent behavior)
    The lamp is dying in one of my Canon imageCLASS MF4150 units (error E225; intermittent washed-out streaks on scans).
    I regrettably lack the right documentation for this; and ENOTIME for taking the contraption apart just to figure out what possibly-integrated part(s) would need swappage, should I choose to actually fix a very
  • teckat
    • 16083
    Re: Canon imageCLASS MF4150 scanner lamp (E225 and consistent behavior)
    Replace the CIS unit=FK2-2869-000
    1) Open the copyboard glass cover [1] and detach it upward.
    Pull out the hinge [2] on the left side while tilting it toward the rear side.
    Be sure to put the copyboard glass cover that you detached onto the mount
    etc., so as not to damage the cable.
    2) Remove the 4 screws [3], and detach the copyboard glass cover [4].
    3) Remove the copyboard glass cover [5].
    Be sure not to get the bottom surface of the scanner glass soiled.
    4) Remove the 2 spacers [1].
    5) Remove the contact sensor unit [2] upward.
    Points to Note at Attaching
    Be sure to fit the gear [1] of the belt with the gear [2] on the bottom surface of the contact sensor unit.
    6) Disconnect the connector [1].
    7) Turn the contact sensor [1] in the direction shown by the arrow, remove
    the 2 shafts [2]
    , and then remove the contact sensor [1].
      • teckat
        • 16083
        The Dude.jpgthanks, & good luck
        • kirolos
          impressive reply
          I need your help because my Canon imageCLASS MF4150 doesn't work any more
          when I connect the power to it the LCD panel flashes for seconds and then I listen to some motors going, but the connected computer doesn't see it
          and the LCD and all its buttons with no light or respond
          any suggestion ?
          Thanks a lot
          • teckat
            • 16083
            Originally posted by kirolos
            impressive reply
            any suggestion ?
            Thanks a lot
            The machine's control panel consists of the following PCBs, and is controlled by the SCNT board.
            SCNT board<->ASIC
            SCNT board<->ASIC <->Operation panel
            LED
            LCD
            Key SW
            In the case of troubles with power supply PCB such as short circuit to loads, and resulted in occurring overcurrent or over over voltage, there is a protecting function for overcurrent/over voltage to automatically shut the output voltage to avoid fault of power supply PCB.
            In the case that the protecting function for overcurrent/over voltage is activated, it recovers by turning off the main power switch to handle the load trouble, and then, turning on the main switch again. Also, there are 2 pc of fuses in PCB. If there is overcurrent in AC line, fuse is blown out and power distribution is shutdown.
            first thing is to check for proper wall voltage supply/ where are u located ?
            do u have a voltage meter ??
            did u try to get in service mode--additional Functions Key-then #Key
            • kirolos
              SCNT board<->ASIC
              LED
              LCD
              Key SW
              Thanks for your professional answer
              I am located in The US so its 110 and I do have voltage meter could you let me know how to check the fuses
              also I will check the service mode and will keep you posted thanks again for your professional help
              • teckat
                • 16083
                Put the meter on AC Volts, 200V range.
                For residential US service you should have 120V between hot and neutral, 120V between hot and ground, and 0V between neutral and ground.
                Remember: narrow prong is hot, wide prong is neutral, round prong is ground.
                NOTE:
                Don't set your meter to current or you will zap it. Resistance shouldn't damage it, but the reading will be worthless.
                not sure what type of fuses are on that board--
                Remember there are two power supplies in this printer
                1-Power Supply/THIS IS THE ONE TO CHECK
                -Remove the front cover.
                -Remove the right cover.
                -Remove the left cover.
                -Remove the rear cover
                -Remove the power supply board [3].
                - 2 connectors [1]
                - 6 screws [2]
                don't think u need to deal this HVPS which is near fix unit--
                2-High Voltage Power Supply
                • kirolos
                  NOTE:
                  At lease could you tell me how to service the PCB and I will chi for the fuses
                  • teckat
                    • 16083
                    see if they are removable
                    u can do a visual check if fuses are glass/(broken filament) or continuity test
                    if solid / u need to do a continuity test
                    important to understand that if a fuse looks good, it might not in fact be good!
                    Fuses can appear to be fine and have a break in them so small that it cannot be seen by the naked eye! Therefore it is important to check a fuse with an Ohmmeter or a continuity tester instead of assuming that it is good.
                    Use a multimeter and set the range switch to the lowest resistance range to check the fuse. A good fuse will read 0 ohms (depending on what the meter reads when the leads are held together) and a bad fuse will read the same as holding the leads in the air.
                    • ZOOTECH
                      Senior member of CRS
                      • 3375
                      A quick test for a filament type fuse is to flick your finger against the end of the fuse - if the filament vibrates much, it's open.
