Re: Too mauch toner while printing
I am not familiar with that test chart but it looks like you have no grey scale. The grey scale should go from white to black not grey to black as in you picture.
If a print is slightly too dark and you copy that the copier will exaggerate this and make it look worse as your copy shows.
You need to set the machine so it will produce a good grey scale from a network print or test chart copy
