Too mauch toner while printing
    Re: Too mauch toner while printing
    Originally posted by Sahdy
    attached is printed test page then copy of it from the machine copy glass.
    i feel the toner is very bulge in the printed (with my hand).
    I am not familiar with that test chart but it looks like you have no grey scale. The grey scale should go from white to black not grey to black as in you picture.
    If a print is slightly too dark and you copy that the copier will exaggerate this and make it look worse as your copy shows.
    You need to set the machine so it will produce a good grey scale from a network print or test chart copy
    • Sahdy
      • Sep 2011
      • 23
      thanks all. it was optics.
      • nivssluck
        • May 2008
        • 228
        There is too much toer when printing only.
        Canon IR 6000n
        by the way it was also in coping
        in printing and copying...can you just check your primary corona?
        • nivssluck
          • May 2008
          • 228
          #19
            • 16083
            #20
            u can mail my service check/use FedEx
            Procedure is the name of the game/
            obvious first/
            elimination second/
            to prevent frustration & headaches
